Version: 8.3
8.1 to 8.3 SDK Upgrade Guide
Please read this page carefully to ensure you are aware of any special considerations and actions required to successfully upgrade an existing module or develop a new 8.3 module. The following sections detail API changes made from 8.1 to 8.3, and are organized by subsystem.
Core
Module Lifecycle
The lifecycle of modules has changed in Ignition 8.3. Modules are no longer started or stopped while the Gateway is already running. Instead, they are set up and started as the Gateway is starting, and shut down as the Gateway is shutting down. Any module changes while the Gateway is running will wait until a Gateway restart to take effect.
This change did not change the signatures of GatewayModuleHook’s lifecycle methods:
  • setup(GatewayContext)
  • startup(LicenseState)
  • shutdown()
Module Acceptance Required
Modules in the user-lib/modules folder will no longer automatically be loaded on startup without a corresponding entry in data/modules.json indicating positive acceptance of the module.
Gateway Network
Java serialization is no longer supported for 8.3 to 8.3 Gateway Network Communication (Java serialization will still be supported for 8.1 to 8.3 Gateway Network Communication as needed). Java objects that are sent between 8.3 Gateways over the Gateway Network must now provide a Protobuf implementation class for the object. To do so, an implementation of the com.inductiveautomation.metro.api.ProtobufSerializable interface must be created, which can convert the Java object to a Protobuf object suitable for serialization. This implementation class must be registered in the Gateway Network using com.inductiveautomation.metro.api.MetroProtobufRegistry#register().
Note that 7.9 Gateways will not be allowed to connect to 8.3 Gateways, even over a proxy Gateway Network connection.
Method Changes
8.1 Method8.3 Method
GatewayAreaNetworkManagerGatewayNetworkManager
GatewayAreaNetworkManagerImplGatewayNetworkManagerImpl
Security
The following APIs were moved from gateway-api to gateway, and are no longer part of public API. The changed API was not originally intended for third party use, so there should not be any major consequences from this update. These changes were implemented to remove accumulated technical debt. Refer to the com.inductiveautomation.ignition.gateway items below for the complete list of removed API:
com.inductiveautomation.ignition.gateway.auth
  • adapter
    • AuthAdapter
com.inductiveautomation.ignition.gateway.config
  • AbstractTypedConfig
com.inductiveautomation.ignition.gateway.http
  • HttpRequest
com.inductiveautomation.ignition.gateway.mapper.attr
  • user
    • UserAttributeMapperConfig
  • AttributeMapper
  • AttributeMapperAdapter
  • AttributeMapperAdapterException
  • AttributeMapperConfig
  • AttributeMapperException
com.inductiveautomation.ignition.gateway.security.level
  • policy
    • AuthenticatedDerivedSecurityLevelPolicyNode
    • DerivedPolicySecurityLevelConfig
    • DerivedSecurityLevelPolicy
    • DerivedSecurityLevelPolicyAdapter
    • DerivedSecurityLevelPolicyAdapterException
    • DerivedSecurityLevelPolicyConfig
    • DerivedSecurityLevelPolicyNode
    • DirectSecurityLevelPolicy
    • DirectSecurityLevelPolicyConfigCollection
    • SecurityLevelPolicyEvaluationContext
    • SecurityLevelPolicyManagerException
com.inductiveautomation.ignition.gateway.user
  • UserAttribute
com.inductiveautomation.ignition.gateway.web
  • attr
    • AttributeSource
    • AttributeSourceException
  • response
    • WebAuthResponseContext
  • session
    • WebAuthSession
    • WebAuthSessionChangeEvent
    • WebAuthSessionContext
  • state
    • WebAuthState
  • strategy
    • AbstractWebAuthStrategy
    • WebAuthStrategy
    • WebAuthStrategyAdapter
    • WebAuthStrategyAdapterException
    • WebAuthStrategyConfig
    • WebAuthStrategyContext
    • WebAuthStrategyException
  • WebAuthRequestCollection
Web Refactoring
Web Server
Java Servlet Spec will be upgraded from 4.EE8 to 6.EE10, which means all servlet APIs will have their packages renamed from javax.* to jakarta.*.
GSON Serializers Moved
The GSON serializers previously found at com.inductiveautomation.ignition.gateway.web.pages.status.serializers and com.inductiveautomation.ignition.gateway.web.pages.config.serializers were moved to package com.inductiveautomation.ignition.gateway.web.serializers.
Project System
Removed Methods:
  • GatewayModuleHook.initializeResourceTypeAdapterRegistry(ResourceTypeAdapterRegistry)
  • ResourceUtil.getValidResourceName()
Updated Methods:
  • Uses of Project have been changed to ResourceCollection
    • This change also resulted in the GET request being excluded, as the methods are still functional without it, so com.inductiveautomation.ignition.common.project.ProjectManifest.getTitle() is now com.inductiveautomation.ignition.common.resourcecollection.ResourceCollectionManifest.title().
  • The terminology for Resource.getData() remains unchanged, but it will now return Optional<ImmutableBytes> instead of @Nullable byte[].
  • Refactored the ImageManager interface to use the 8.3 resource-based configuration storage.
Designer
  • The entire resource commit process has been made asynchronous, which guarantees the notifyProjectSaveStart and notifyProjectSaveDone methods on DesignerModuleHook are called off the EDT.
  • The abort method on the SaveContext delivered in notifyProjectSaveStart has been removed. Any error during the save process are now thrown directly.
Scripting
  • Revamped ScriptFunctionDocProvider, including adding the option to return rich CompletionDescriptor objects. PropertiesFileDocProvider has been accordingly revamped, in a backwards compatible manner. Refer to the Javadocs for PropertiesFileDocProvider for the new property keys and functionalities now available.
    • Some annotations were renamed in a backwards incompatible way. For example, since system libraries can now expose static fields and constants, a new annotation @JythonElement is used instead of @ScriptFunction.
  • Revamped ScriptContext for improved developer experience. This will affect developers creating their own scripting execution context, such as running user authored extension function style scripts, and is documented in the class.
RPC
The RPC mechanism that relies on Java serialization has been deprecated.
  1. Define a Java interface in common scope and annotate it with @RpcInterface, defining a package ID for namespacing the interface.
  2. Implement this interface in your Gateway scope, in a regular Java class.
  3. Construct your interface implementation(s), and pass them to GatewayRpcImplementation.of to construct an automatic routing and handling RpcDelegate for your interfaces.
  4. Return this constructed instance from GatewayModuleHook.getRpcImplementation().
  5. In the Designer/Client, use the static GatewayConnection.getRpcInterface() method to obtain a proxy instance of your interface. This proxy will automatically issue calls to the Gateway.
  6. Use com.inductiveautomation.ignition.common.rpc.proto.ProtoRpcSerializer.DEFAULT_INSTANCE if you want to take advantage of Ignition's Protobuf-based serialization approach, or construct a new builder to extend it with your own GSON, Protobuf, or other sub serializers for module specific classes.
Backwards Compatibility
Individual callers within the Designer/Client UI should be responsible for making their calls async appropriately and handling comm or timeout exceptions, but some existing legacy methods to wrap calls still exist for backwards compatibility.
A new com.inductiveautomation.ignition.client.util.gui.progress.Task Task class has been added, which can wrap up a function that potentially throws and either execute it blocking on the EDT while still showing progress status in a modal dialog. This should only be used for backwards compatibility. Alternatively, it can be called asynchronously on a background thread, reporting task statuses automatically to the local Designer/Client.
Push Notifications
The SDK API around push notifications on the Gateway is effectively the same, but with the addition of a trailing serialization argument, where developers are now in charge of marshalling message payloads to binary over the wire. Similarly, each PushNotificationListener must register its own deserializer capable of reading bytes off the wire and turning them back into a useful message class.
Deprecated Methods/Classes
Common API
  • Removed SecurityUtils#decryptRSA
  • Removed SecurityUtils#getKeyParameter, SecurityUtils#getPrivateKeyParameter, SecurityUtils#asymmetricSign, and SecurityUtils#generateDESedKey
Gateway API
  • Removed SystemMap, GatewayModuleHook#updateSystemMap(SystemMap), and RedundancyManager.getPeerSystemMap()
  • Removed GatewayContext#getLaunchManager()
  • Removed the LaunchDescriptor class
  • Removed the LaunchFlavor class
  • Removed the LaunchHandler class
  • Removed the LaunchManager class
  • Removed the SmtpManager class, including accessor on GatewayContext, and the EmailProfilerManager class
Redundancy
  • Removed the RuntimeStateProvider interface. This is replaced by the SnapshotStateProvider interface.
Altered Routes
The system/projectlist route is now split into system/launchDesigner and system/launchVision, where launchVision is only available if the Vision module is installed. These new routes now return JSON.
Launchers
8.3 Gateways require 1.3.0+ Launchers to function. These new versions are bundled with 8.3 Gateways by default, and retain compatibility with 8.1 Gateways. Note that the DeepLinks and File Associations features introduced with the 1.3.0 launchers are not backwards compatible, but are compatible with launching against 8.1.x Gateways. Additionally, a new DLL is included with the Windows Launchers to provide an Explorer Shell Extension to support custom icons for file associations. It is optional during All User installation. Custom icons are configured under Project Properties > Launch Icon.
Workstation Only
An additional property, allow.uri.schemes, has been added to the workstation configuration JSON. This property is an allow-list of URI schemes that will be opened by the Host OS. Schemes that should be supported by this mechanism must be in this list. It's pre-seeded with Designer, Vision, and Perspective.
Modules
Perspective
EventBus
Ignition version 8.1.17 introduced the EventManager class to replace uses of EventBus. EventBus has been completely removed with Ignition 8.3, and modules still using the EventBus class must switch to the EventManager implementation, which has an identical interface.
New Supported Browser Versions
The basic Session functionality requirements have been updated for a variety of reasons, such as security patches, new API features, and general lack of support for older browsers. The following table displays the difference between the browser versions required by type for Ignition 8.1 and 8.3.
BrowserMinimum Version
Required in 8.1
Minimum Version
Required in 8.3
Chrome57≥92
Firefox52≥90
Safari11≥15.4
Edge16≥92
EAM
The following service calls have been removed.
BackupService
  • BackupService#requestGatewayBackup
    • Replaced with BackupService#requestGatewayBackupAsync
  • BackupService#streamGatewayBackup
  • BackupService#requestModules
    • Replaced with BackupService#requestModulesAsync
  • BackupService#restoreBackup
    • Replaced with BackupService#restoreBackupAsync
InfoService
  • InfoService#getControllers
  • InfoService#getRemoteServers
SendTagsService
  • SendTagsService#importTags
UpgradeService
  • UpgradeService#triggerUpgrade
    • Replaced with UpgradeService#triggerUpgradeAsync
OPC UA
Driver/Device API
As a consequence of the platform-level ExtensionPoint API changes, DriverType and DeviceType have been replaced by the new DeviceExtensionPoint. All of the classes in the previously deprecated com.inductiveautomation.xopc.driver.api have been removed from the public API. This includes the Driver interface. All third party driver implementations must implement the Device interface, which has been simplified for improved usability.
OPC Connections - Milo 1.0
Some classes and packages from the milo-server-sdk artifact have been relocated or renamed. Device implementations may need to update their import statements in addition to any other changes needed to accommodate the new Device API.
Reporting
QuerySources and RPC Serialization
Module authors that register their own QuerySources should be aware that their QuerySources will result in serialization errors when using RPC if these sources cannot be serialized with the default GSON serialization.
New Secrets Management API
A new secrets manager has been created and added to the 8.3 codebase to provide better support for distinct secrets in the Ignition platform. As a developer migrating code from the old PersistentRecord API to the new Config Resource API, you might come across the problem of how to migrate secrets properly.
In general, if your old PersistentRecord class has an EncodedStringField property on it, then it is a secret. In your new config resource class/record, add a new field of type com.inductiveautomation.ignition.gateway.secrets.SecretConfig. If you use the DefaultRecordEncodingDelegate, it will know how to migrate your secret from the old EncodedStringField to the new SecretConfig, and there is nothing more needed as far as migration is concerned. In case you are doing some custom encoding, you can directly use the GsonAdapter class nested in the SecretConfig class to perform the Gson encoding/decoding of SecretConfigs yourself.
Note that when your system loads from the new resource API, secrets are no longer considered static. This is because secrets may be referenced from a secret provider. The intention is to load the secret on demand.
Example: Load a Plaintext Value of a Secret at Runtime
String getPassword(gatewayContext context, MyConfigResource resource) throws Exception {
SecretConfig secretConfig = resource.getPassword();
Secret<?> secret = Secret.create(gatewayContext, secretConfig);
Plaintext plaintext = secret.getPlaintext();
String password;
try {
return plaintext.getAsString(StandardCharsets.UTF_8);
} finally {
// password is kept around as a String anyway, but might as well clear the bytes
// held by the Plaintext instance...
plaintext.clear();
You can hold onto your Secret instance as long as your config resource has not changed. You can repeatedly call getPlaintext() to get the latest value of the secret on demand.
note
It is best to keep the secret in the form of a byte array or char array, and to “clear” the array with zeros or spaces when done. This helps to reduce the amount of time the plaintext secret value is in memory, which reduces the likelihood of the plaintext value leaking somehow through memory analysis.
However, if you must convert to a String due to the API only accepting secrets as Strings, clearing the Plaintext instance after grabbing the value as a String means you’ll have to rely on the garbage collector reclaiming the String when no longer used.
