Version: 8.3
Scopes, Hooks, and Contexts
Scopes​
Ignition defines three different scopes: the gateway, the designer, and the client. A module may include pieces for multiple scopes, and resources in a module can be assigned to multiple scopes at once.
For each scope that your module will run in, it will define a module hook. This is the entry point for the module in that scope, and provides several lifecycle functions. Each scope provides a context to the hook, which can be used to access all of the platform services of that scope.
Module Hooks​
There are three interfaces that define the hooks that correspond to the scopes:
  • GatewayModuleHook
  • DesignerModuleHook
  • ClientModuleHook
Each module hook must be defined in the module descriptor file.
tip
You don't need to create these hooks from scratch if you generate your project from the Ignition plugins for Gradle or Maven. Refer back to Create a Module and follow the prompts to define your scopes.
In practice, it is best to extend from the Abstract implementations of these hooks (for example, AbstractGatewayModuleHook) instead of implementing the interfaces yourself. An Abstract class provides empty implementations of the functions, allowing you to implement only what you need. Subclasses extending from the Abstract class define the specific and relevant functions you need. For example, in our tutorial example we extended from the AbstractGatewayModuleHook in order to access the initializeScriptManager() method:
GatewayHook.java
public class GatewayHook extends AbstractGatewayModuleHook {
@Override
public void initializeScriptManager(ScriptManager manager) {
super.initializeScriptManager(manager);
manager.addScriptModule(
"system.example",
scriptModule,
new PropertiesFileDocProvider());
Each hook also provides up to three lifecycle functions:
setup()​
Called before startup. This is the chance for the module to add its extension points and update persistent records and schemas. None of the managers will be started up at this point, but the extension point managers will accept extension point types.
startup()​
The main entrypoint for the module hook. This will only be called once for a given project. If another project is ever opened, shutdown() will be called and a new hook will be instantiated
shutdown()​
Called when the module is shut down.
Contexts​
The context for the given scope will be passed to the setup or startup method of the associated hook. The available contexts will vary depending on the scope of the associated hook. The modules should hold on to these contexts and pass them to subsystems that they define as it is the primary way to access the services provided by the Ignition platform.
