Install a Module
Installing a module you built with the Ignition SDK works the same way as installing any other third-party module.
- On your Gateway, navigate to Config > System > Modules.
- Click Install or Upgrade a Module.
- Click Choose File and select the
.modlfile you want to install. - Click Install.
You can now launch the Designer and use your new module.
