Version: 8.3
Storing Data with PersistentRecords
The PersistentRecord class is your entrypoint to storing and retrieving data in the internal database system. As described in the Key Design Concepts > Storing Configuration Data, you don’t need to worry about replicating data to redundant nodes, writing raw SQL queries, or maintaining tables. Additionally, the PersistentRecord offers convenient methods for listening to record changes.
The persistence interface is used to store any data that should be replicated through redundancy, and offers facilities for working both with single rows (such as module settings) and many rows (such as associated objects). It should not be used directly for project data since the project resource system offers richer facilities for that.
Using PersistentRecords
  1. Define the data by creating a class that extends from PersistentRecord, and defining your own fields that extend from SFieldMeta, such as StringField, LongField, and IntField.
  2. Register the record and verify the table by calling GatewayContext.getSchemaUpdater().updatePersistentRecords.
  3. Use the methods on the PersistenceInterface to create, read, update, and delete persistent records.
  4. Optional: Listen for changes to your record by adding an IRecordListener to its META object.
Defining a PersistentRecord
A custom PersistentRecord type starts by extending that class. Then, define a series of public, static fields and a public static META field.
RecordMeta Object
RecordMeta is used to create new instances, identify records, and more. It’s common to declare this as a public, static field in your custom record because of how frequently it is used.
Field Definitions
Fields are defined using special classes that represent different data types and are declared as public, static variables. The full list of data types can be found in the JavaDocs, but some of the most common are: IntField, DoubleField, DateField, StringField, BooleanField, and EnumField. The fields are defined with a name and support common operations such as setting a default value or setting a not-null constraint. Additional aspects are defined by the SFieldFlags, such as whether the field is a key. See the JavaDocs for that enum for more information.
Identity Fields
Another important field type is the IdentityField. This field translates to a unique, automatically assigned long value. It also defines itself as the primary key, or identifier, for the record. In most cases, it's convenient to use the IdentityField as the unique element in a record. However, it's possible to declare any field as the primary key using the SFieldFlags.SPRIMARY_KEY field flag.
Often records will be related to other records. By defining that relation, it's easy to navigate them when querying. To define a relationship to another record, two field definitions are required:
  • A field that represents the primary key of the other record
  • A ReferenceField that uses the first field to connect the two
For example, internal SQLTags have TagRecords and TagPropertyRecords. Each tag can have many properties. The TagPropertyRecord relates back to the tag record using the tag's Long id. This is in the TagPropertyRecord:
TagPropertyRecord Example
public static final LongField TagId = new LongField(META, "TagId");
public static final ReferenceField<TagRecord> Tag = new ReferenceField<TagRecord> (META, TagRecord.META, "Tag", TagId);
As another example, you could add the following two fields if you wanted to put a reference in your own record that pointed to a database connection.
TagPropertyRecord Example Continued
public static final LongField ConnectionId = new LongField(META, "ConnectionId"); public static final ReferenceField<DatasourceRecord> Connection =
new ReferenceField<DatasourceRecord>(META, DatasourceRecord.META, "Connection", ConnectionId);
Setting and Retrieving Values of Fields
Each field type has associated get and set functions defined for it in the PersistentRecord base class. For example, to get the value of a string field called "Name", you would use getString(Name). Often, for code clarity, it is better to define standard getters and setters in the record that delegate to these functions. The example below illustrates this technique:
Setting and Retrieving Values Example
public class MySettingsRecord extends PersistentRecord {
public static final RecordMeta<MySettingsRecord> META = new RecordMeta<MySettingsRecord>(MySettingsRecord.class,"MySettings");
public static final IdentityField Id = new IdentityField(META);
public static final StringField Name = new StringField(META, "Name", SFieldFlags.SMANDATORY, SFieldFlags.SDESCRIPTIVE);
public static final BooleanField TurboEnabled = new BooleanField(META, "TurboEnabled", SFieldFlags.SDESCRIPTIVE).setDefault(true);
public static final IntField CommunicationTimeout = new IntField(META, "CommunicationTimeout").setDefault(5000);
public Long getId(){
return getLong(Id);
public String getName(){
return getString(Name);
public void setName(String name){
setString(Name,name);
Registering the PersistentRecord
In order to store and retrieve your persistent record, it must be registered with the persistence interface so that the table can be created. This is done using the SchemaUpdater provided by the GatewayContext, and is normally done in the setup function of the module or class that uses the record.
SchemaUpdater Example
public void setup(GatewayContext context) {
context.getSchemaUpdater().updatePersistentRecords(MySettingsRecord.META);
The SchemaUpdater has additional functions for ensuring that only a single instance of a record exists. This is useful to hold any ‘singleton’ settings that will always be unique across a Gateway, such as Gateway security settings, or the ‘Live Event Limit’ for alarming.
Using the Persistence Interface
Creating and Saving Record Instances
All CRUD operations for a PersistentRecord are executed through the PersistenceInterface. The JavaDocs for that interface outline all of the available functions, but to create a basic record and save it you can use the createNew() and save() functions.
Example
MySettingsRecord r = context.getPersistenceInterface().createNew(MySettingsRecord. META);
r.setName("Test");
r.setCommunicationTimeout(1000); context.getPersistenceInterface().save(r);
Modified data in a record is not stored to the database until save() is called. Although more advanced methods for saving records exist, this function is the most convenient method for single records.
Querying Records
Records are also retrieved through the PersistenceInterface. Retrieval is accomplished via the query() and find() functions. The query function allows you to build complex search queries and specify additional properties, such as ordering. Queries are built using the SQuery object, which is a fluent builder supporting chained calls.
The find function differs in that it takes primary key values to find a specific tag.
Query example to find instances with of MySettingsRecord with turbo enabled
SQuery<MySettingsRecord> query = new SQuery<MySettingsRecord>(MySettingsRecord.META).isTrue(MySettingsRecord.TurboEnabled) List<MySettingsRecord> results;
results = this.getGatewayContext().getPersistenceInterface().query(query);
Aggregating Operations using Sessions
When performing any operation, the persistence interface uses sessions and datasets to execute commands. In the examples above, sessions are created automatically and closed after the command is executed. For performance and data consistency, it is often useful when performing multiple operations together to create your own session, modify its dataset, and commit it when finished.
A PersistenceSession object is generated by calling getSession() on the persistence interface. After retrieving a session, you can get its dataset with getDataSet(). The dataset can be used to modify rows. When finished, commit the modified dataset through session.commit(). If an error occurs, all changes can be reversed with session.rollback().
Listening for Changes to Records
Often, you'll want to be notified when a type of record you're interested in changes. This can be accomplished by implementing an IRecordListener and registering it on a record's META. This interface defines functions that will be called any time a record of the specified type is added, removed, or modified. If you're only interested in one or two of these operations, it is easier to extend the RecordListenerAdapter class and override the functions you want.
For example, making sure you’re notified when your MySettingsRecord is modified could look like the following:
Declare an anonymous subclass
MySettingsRecord.META.addRecordListener(new RecordListenerAdapter<MySettingsRecord> () {
@Override
public void recordUpdated(MySettingsRecord record) {
applyNewSettings(record);
In this example block, we're using the ability to declare an anonymous subclass inline in order to extend RecordListenerAdapter and provide our own implementation of recordUpdated. When it's called, we simply call a different function that should update our module with the new settings.
