Version: 8.3
Examine the Example
Let's examine some pieces of the example module to see how they interact to create a scripting function.
note
This is not an exhaustive list of every file or class required to make this example work. We encourage you to examine the other directories included in this example project to see how they all fit together.
common​
The common directory defines the interface and abstract class that all the implementing functions must adhere to, regardless of scope. This directory contains the files that define the function itself:
  • AbstractScriptModule.java
  • MathBlackBox.java
AbstractScriptModule​
The AbstractScriptModule class defines the function and its arguments:
@ScriptFunction(docBundlePrefix = "AbstractScriptModule")
public int multiply(@ScriptArg("arg0") int arg0,
@ScriptArg("arg1") int arg1) {
return multiplyImpl(arg0, arg1);
MathBlackBox​
The AbstractScriptModule implements the abstract class MathBlackBox to provide the math behind the multiply() scripting function:
MathBlackBox.java
package com.inductiveautomation.ignition.examples.scripting.common;
public interface MathBlackBox {
public int multiply(int arg0, int arg1);
ClientScriptModule​
An instance of ClientScriptModule is used in the Designer and Client scope to provide details about the function. The ClientScriptModule class creates the actual RPC handler, using the API's ModuleRPCFactory.create() method:
/src/main/java/com/inductiveautomation/ignition/examples/scripting/client/ClientScriptModule.java
public ClientScriptModule() {
rpc = ModuleRPCFactory.create(
"com.inductiveautomation.ignition.examples.scripting.ScriptingFunctionG",
MathBlackBox.class
The ModuleRPCFactory handles passing values back and forth between scopes.
GatewayScriptModule​
When executed, the ModuleRPCFactory will automatically call the GatewayHook's getRPCHandler method, which returns the GatewayScriptModule with the actual implementation of MathBlackBox:
gateway/src/main/java/com/inductiveautomation/ignition/examples/scripting/GatewayScriptModule.java
package com.inductiveautomation.ignition.examples.scripting.gateway;
import com.inductiveautomation.ignition.examples.scripting.common.AbstractScriptModule;
public class GatewayScriptModule extends AbstractScriptModule {
@Override
protected int multiplyImpl(int arg0, int arg1) {
return arg0 * arg1;
