Version: 8.3
Component Overview
JavaBean Properties​
To expose a property, make it accessible via JavaBean-style getter/setter functions. For example, if you have a String field called "title" on your component, you would add these functions to expose the property:
MyComponent.java
public String getTitle() {
return title;
public void setTitle(String title) {
this.title = title;
As long as the title property is included in your component's BeanInfo class, it will appear in the Property Table pane when your user selects the component in the Designer. The user can set the property's value, bind it to a tag, and more.
Bound Properties​
Components have two major types of properties: normal properties and bound properties. All properties whose type is understood by Ignition can use the binding system. That is, the user can configure a binding on that property. However, only bound properties can be bound to.
To understand this, look at the Text Field component. It has many properties. Now put a Label on a window and bind the text of the Label to the Text Field's text. You'll notice that the list of the Text Field's properties that you can bind the Label's text to is much shorter than the whole list of properties for the Text Field. This shorter list is the list of bound properties. A better name for these might be properties that can be bound to.
There are two things that make a property a bound property:
  • In the component's BeanInfo class, the component is marked as a bound property with the BOUND_MASK.
  • The component property fires the propertyChangeEvent when the field is altered. This event is what powers the binding system. For example, to allow the title field to fire events, you can alter the setter function to this:
MyComponent.java
String oldValue = this.title;
this.title = title;
firePropertyChange("title", oldValue, title);
Special Abilities​
There are a few special abilities that Vision users expect a component to have:
  • Dynamic properties
  • Quality overlays
  • Styles
  • Cursor and name collision handling
To save you the trouble of implementing a handful of interfaces that you may not be familiar with, the Vision module provides abstract base classes that you are encouraged to extend. Extending from the AbstractVisionComponent, AbstractVisionPanel, and AbstractVisionScrollPane classes will give you access to all of the special abilities that your users will expect.
The following example extends from the AbstractVisionComponent class to access methods from LocaleListener:
HelloWorldComponent.java
public class HelloWorldComponent extends AbstractVisionComponent implements LocaleListener {
* This function is called whenever the user's locale changes. Add code here to deal with any
* translations, number formats, or date formats that need to change as a result of the locale
* changing. Some items may need to be revalidated/repainted to cause the screen to update.
@Override
public void localeChanged(Locale locale) {
//We need to fire a change on text in order to trigger html based displays to refresh.
firePropertyChange("text", null, getText());
repaint();
Lifecycle​
All Vision components are expected to implement the VisionComponent interface. This defines quality monitoring behavior as well as the ComponentLifecycle behavior. ComponentLifecycle is an interface that defines a startup and shutdown method.
The startup method gives you the VisionClientContext, which allows you to reference the rest of the system. Most importantly, it lets your component know when to shut itself down. Any component that has long-running background processes (threads) needs to shut them down when the shutdownComponent() function is called. This function is called when the window that contains the component is closed:
@Override
protected void onStartup() {
// Seems like a no-op, but actually will trigger logic to re-start the timer if necessary
setAnimation(animation);
@Override
protected void onShutdown() {
if (_timer != null && _timer.isRunning()) {
_timer.stop();
