Version: 8.3
Browse Tags
// This code example is Gateway scoped and assumes the `GatewayContext` object is available.
private void browseTags() throws Exception {
IgnitionGateway context = IgnitionGateway.get();
GatewayTagManager tagManager = context.getTagManager();
TagProvider provider = tagManager.getTagProvider("default"); // Change tag provider name here as needed
TagPath root = TagPathParser.parse("");
browseNode(provider, root);
private void browseNode(TagProvider provider, TagPath parentPath) throws Exception {
Results<NodeDescription> results = provider.browseAsync(parentPath, BrowseFilter.NONE).get(30, TimeUnit.SECONDS);
if(results.getResultQuality().isNotGood()) {
throw new Exception("Bad quality results: "+ results.getResultQuality().toString());
Collection<NodeDescription> nodes = results.getResults();
StringBuilder structure = new StringBuilder();
for(int i = 0; i<parentPath.getPathLength(); i++) {
structure.append("\t");
String formatted = structure.toString() + "[%s] objectType=%s, dataType=%s, subTypeId=%s, currentValue=%s, displayFormat=%s, attributes=%s, hasChildren=%s";
for(NodeDescription node: nodes) {
String currentValue = node.getCurrentValue().getValue() != null ? node.getCurrentValue().getValue().toString(): "null";
String descr = String.format(formatted, node.getName(),
node.getObjectType(),
node.getDataType(),
node.getSubTypeId(),
currentValue,
node.getDisplayFormat(),
node.getAttributes().toString(),
node.hasChildren());
// logger.info(descr);
// Browse child nodes, but not Document nodes such as UDT parameters
if(node.hasChildren() && DataType.Document != node.getDataType()) {
TagPath childPath = parentPath.getChildPath(node.getName());
browseNode(provider, childPath);
