Version: 8.3
Import Tags
// This code example is Gateway scoped and assumes the `GatewayContext` object is available.
private void importTags() throws Exception {
IgnitionGateway context = IgnitionGateway.get();
GatewayTagManager tagManager = context.getTagManager();
TagProvider provider = tagManager.getTagProvider("default"); // Change tag provider name here as needed
// Note that it is normally better to import tag json from a File object. We are using Strings here to keep
// the example simple.
String basicUdtDef = getUdtDefImport();
String udtInstances = getUdtInstancesImport();
// Import the definition first
TagPath importPath = TagPathParser.parse("_types_");
// Using the Ignore collision policy here to make sure we don't accidentally overwrite existing tags.
List<QualityCode> results = provider.importTagsAsync(importPath, basicUdtDef, "json", CollisionPolicy.Ignore).get(30, TimeUnit.SECONDS);
for (int i = 0; i < results.size(); i++) {
QualityCode result = results.get(i);
if (result.isNotGood()) {
throw new Exception(String.format("Add tag operation returned bad result '%s'", result.toString()));
// Then import the instances. Note that if the UDT definitions and instances are in the same tag json import file, then we
// don't need to perform two separate imports.
importPath = TagPathParser.parse("");
results = provider.importTagsAsync(importPath, udtInstances, "json", CollisionPolicy.Ignore)
private String getUdtDefImport() {
return "{\n"
+ " \"dataType\": \"Int4\",\n"
+ " \"name\": \"BasicUDTDef\",\n"
+ " \"value\": 0,\n"
+ " \"parameters\": {\n"
+ " \"MyParam\": \"paramval\",\n"
+ " \"MyIntegerParam\": -1.0\n"
+ " },\n"
+ " \"tagType\": \"UdtType\",\n"
+ " \"tags\": [\n"
+ " {\n"
+ " \"eventScripts\": [\n"
+ " {\n"
+ " \"eventid\": \"valueChanged\",\n"
+ " \"script\": \"\\tprint \\\"Value changed!\\\"\"\n"
+ " }\n"
+ " ],\n"
+ " \"valueSource\": \"memory\",\n"
+ " \"name\": \"MemberEventScriptTag\",\n"
+ " \"value\": 10,\n"
+ " \"tagType\": \"AtomicTag\"\n"
+ " },\n"
+ " {\n"
+ " \"name\": \"UdtFolderLevelOne\",\n"
+ " \"tagType\": \"Folder\",\n"
+ " \"tags\": [\n"
+ " {\n"
+ " \"dataType\": \"Float4\",\n"
+ " \"alarms\": [\n"
+ " {\n"
+ " \"mode\": \"AboveValue\",\n"
+ " \"setpointA\": 100.0,\n"
+ " \"name\": \"HighValue\",\n"
+ " \"priority\": \"High\"\n"
+ " }\n"
+ " ],\n"
+ " \"name\": \"BasicTypeAlarmTag\",\n"
+ " \"value\": 0.5,\n"
+ " },\n"
+ " {\n"
+ " \"valueSource\": \"expr\",\n"
+ " \"expression\": \"{MyParam}\",\n"
+ " \"dataType\": \"String\",\n"
+ " \"expressionType\": \"Expression\",\n"
+ " \"name\": \"BasicTypeExpressionTag\",\n"
+ " \"value\": \"\",\n"
+ " },\n"
+ " {\n"
+ " \"name\": \"UdtFolderLevelTwo\",\n"
+ " \"tags\": [\n"
+ " {\n"
+ " \"documentation\": {\n"
+ " \"bindType\": \"parameter\",\n"
+ " \"binding\": \"MyIntegerParam set to {MyIntegerParam}\"\n"
+ " },\n"
+ " \"tooltip\": {\n"
+ " \"binding\": \"UDT instance {MyParam}\"\n"
+ " },\n"
+ " \"name\": \"LevelTwoMemoryTag\",\n"
+ " \"value\": 2,\n"
+ " }\n"
+ " ]\n"
+ " }\n"
+ " ]\n"
+ " }\n"
+ " ]\n"
private String getUdtInstancesImport() {
return "{\n"
+ " \"tags\": [\n"
+ " {\n"
+ " \"name\": \"BasicUDT_Instance0\",\n"
+ " \"typeId\": \"BasicUDTDef\",\n"
+ " \"MyParam\": \"Param for Basic UDT Instance\",\n"
+ " \"MyIntegerParam\": 0.0\n"
+ " },\n"
+ " \"tagType\": \"UdtInstance\",\n"
+ " \"tags\": [\n"
+ " {\n"
+ " },\n"
+ " {\n"
+ " \"tags\": [\n"
+ " {\n"
+ " },\n"
+ " {\n"
+ " \"tags\": [\n"
+ " {\n"
+ " }\n"
+ " ]\n"
+ " },\n"
+ " {\n"
+ " }\n"
+ " ]\n"
+ " }\n"
+ " ]\n"
+ " },\n"
+ " {\n"
+ " \"name\": \"BasicUDT_OverrideInstance0\",\n"
+ " \"MyParam\": \"Param for Basic UDT override instance\",\n"
+ " \"MyIntegerParam\": 1.0\n"
+ " },\n"
+ " \"tags\": [\n"
+ " {\n"
+ " {\n"
+ " \"script\": \"\\tprint \\\"Override: Value changed!\\\"\"\n"
+ " }\n"
+ " ],\n"
+ " },\n"
+ " {\n"
+ " \"tags\": [\n"
+ " {\n"
+ " \"tags\": [\n"
+ " {\n"
+ " \"value\": \"4\",\n"
+ " }\n"
+ " ]\n"
+ " },\n"
+ " {\n"
+ " \"enabled\": false,\n"
+ " },\n"
+ " {\n"
+ " {\n"
+ " \"setpointA\": 200.0,\n"
+ " },\n"
+ " {\n"
+ " \"mode\": \"BelowValue\",\n"
+ " \"setpointA\": 10.0,\n"
+ " \"name\": \"LowValue\"\n"
+ " }\n"
+ " ],\n"
+ " }\n"
+ " ]\n"
+ " }\n"
+ " ]\n"
+ " }\n"
+ " ]\n"
