Version: 8.3
Read and Write Tags
// This code example is Gateway scoped and assumes the `GatewayContext` object is available.
private void writeReadTagValue() throws Exception {
IgnitionGateway context = IgnitionGateway.get();
GatewayTagManager tagManager = context.getTagManager();
TagProvider provider = tagManager.getTagProvider("default"); // Change tag provider name here as needed
TagPath memoryTag0 = TagPathParser.parse("MemoryTag0");
QualifiedValue newQv = new BasicQualifiedValue(43);
// Write out a new value. Note that we are using SecurityContext.emptyContext(), as we are not working with
// user roles or security zones in this example.
List<QualityCode> results = provider.writeAsync(Arrays.asList(memoryTag0), Arrays.asList(newQv), SecurityContext.emptyContext()).get(30, TimeUnit.SECONDS);
QualityCode qc = results.get(0);
if(qc.isNotGood()) {
throw new Exception(String.format("Write tag value operation returned bad result '%s'", qc.toString()));
// Read the updated value
List<QualifiedValue> values = provider.readAsync(Arrays.asList(memoryTag0), SecurityContext.emptyContext())
QualifiedValue qv = values.get(0);
if(qv.getQuality().isNotGood()) {
throw new Exception(String.format("MemoryTag0 cannot be read, quality=" + qv.getQuality().toString()));
} else {
String qvValue = qv.getValue() != null ? qv.getValue().toString(): "null";
// logger.infof("MemoryTag0 value='%s'", qvValue);
private void writeReadTagProperty() throws Exception {
TagPath memoryTag1Doc = TagPathParser.parse("LevelOne_FolderA/MemoryTag1." + WellKnownTagProps.Documentation.getName());
QualifiedValue newQv = new BasicQualifiedValue("Updated documentation for MemoryTag1");
// Write out the tag property. Note that we are using SecurityContext.emptyContext(), as we are not working with
List<QualityCode> results = provider.writeAsync(Arrays.asList(memoryTag1Doc), Arrays.asList(newQv), SecurityContext.emptyContext()).get(30, TimeUnit.SECONDS);
if (qc.isNotGood()) {
throw new Exception(String.format("Write tag property operation returned bad result '%s'", qc.toString()));
// Read the tag property.
List<QualifiedValue> values = provider.readAsync(Arrays.asList(memoryTag1Doc), SecurityContext.emptyContext())
if (qv.getQuality().isNotGood()) {
throw new Exception(String.format("MemoryTag1.documentation cannot be read, quality=" + qv.getQuality().toString()));
} else {
// logger.infof("MemoryTag1 documentation='%s'", qvValue);
private void writeReadUdtParameter() throws Exception {
TagPath udtParam = TagPathParser.parse("BasicUDT_OverrideInstance0/parameters/MyParam");
QualifiedValue newQv = new BasicQualifiedValue("Updated param for Basic UDT override instance");
// Write out the udt parameter. Note that we are using SecurityContext.emptyContext(), as we are not working with
List<QualityCode> results = provider.writeAsync(Arrays.asList(udtParam), Arrays.asList(newQv), SecurityContext.emptyContext()).get(30, TimeUnit.SECONDS);
throw new Exception(String.format("Write udt parameter operation returned bad result '%s'", qc.toString()));
List<QualifiedValue> values = provider.readAsync(Arrays.asList(udtParam), SecurityContext.emptyContext())
throw new Exception(String.format("BasicUDT_OverrideInstance0/MyParam cannot be read, quality=" + qv.getQuality().toString()));
} else {
String qvValue = qv.getValue() != null ? qv.getValue().toString() : "null";
// logger.infof("BasicUDT_OverrideInstance0 MyParam ='%s'", qvValue);
